How do Ladder Bars Work?
Old Dec 11, 2006 | 01:28 PM
TransAm Mania's Avatar
Default How do Ladder Bars Work?
I posted a thread a while back regarding ladder bars but I didn't get much feed back. Does any one know how they work (What they prevent or how they imporve it). I want to be able to use the car for street/strip use but am concerned that the ladder bars will be too stiff and riggid for street use. I heard that I will have problems while encountering differences in road heights such as while entering or exiting parking lots which are usually a different height than the street. Can any one help me with these questions? Should I install them on the car, only install them for drag racing, or not even bother?
Thanks
Old Dec 11, 2006 | 09:49 PM
rocket22's Avatar
I'm not really up on ladder bars so to speak,but if you are looking at a pro touring car you would be happier with either a TCI,Alston,DSE 4 link style rear suspension set-up or just leaf springs,ladder bars are old out dated techology.if you want a drag car just go 4 link.
Old Dec 12, 2006 | 12:28 AM
CW00BlackTA's Avatar
The ones I had on my 69 Chevelle bolted to the axle and to a location on the frame about 2.5 feet in front of the axle. When you load the drivetrain, the axle wants to rotate which tends to lift the front of the bars. Since the body of the car resists, the result is downward force on the rear which improves traction.
Old Dec 12, 2006 | 01:29 AM
chicane's Avatar
Read this: http://www.competitionengineering.co...s/chassis2.asp
Its the fifth slide down... and a simple explaination, to get you started until your next series of questions.
