Brake disc recommendations?
Old Dec 25, 2006 | 11:34 PM
BirdmanLS1's Avatar
Default Brake disc recommendations?
Well since i keep hearing how slotted/drilled rotors actually hurt performance, what rotors should i get? I need new rotors and i want hawk pads. Any advice would help, also should i get aftermarket calipers or are stockers ok?
Old Dec 26, 2006 | 12:29 AM
VIP1's Avatar
Copy & Paste Moderator
Blank rotors, example: Brembo OEM blanks (available at TireRack and Sam Strano, both sponsors). The stock calipers are fine unless you've damaged them.
Old Dec 26, 2006 | 12:51 AM
LSGunZ28's Avatar
Bendix is just fine, but for High performance I would probably assume Wilwood or Brembo.
Im using rEBC edstuff pads right now and my brake lines arent even completely bled and I still see better braking than stock. I will install EBC yellowstuff soon, Ill let you know how that goes
BTW Im using Valvoline Synpower Dot 4 brake fluid.
Old Dec 27, 2006 | 01:31 AM
BirdmanLS1's Avatar
What about the C5 brake conversion kit. I have been reading other threads about the conversion, but i dont even know whats all involved with the conversion. Is it the C5 brackets, C5 rotors, C5 calipers, and brake pads? And if so where can i buy the whole kit outright at?
Old Dec 27, 2006 | 05:24 AM
76LS1BIRD's Avatar
Restricted User
http://www.umiperformance.com/
Old Dec 27, 2006 | 10:46 AM
VIP1's Avatar
A search will get you all the info you need. If you cant find anything. I'll try to do some searching for you, but I dont have the time right now. BTW, UMI isn't the only one making brakets and there is a difference among the brakets. Some can use the stock calipers. Some require C5 calipers.
Old Dec 27, 2006 | 11:10 AM
UMI Performance's Avatar
Originally Posted by 76LS1BIRD
Thanks Dale
If you visit this the link below we have quite a bit of information regarding the C5 brake conversion, there is even a link to a brief installation. If you have any questions please ask and I am glad to help.
http://www.umiperformance.com/c5conv.aspx
Hope that helps!
Ryan
