help with noise in front end
Old Dec 31, 2006 | 09:38 AM
schiccc's Avatar
Default help with noise in front end
yesterday i installed kyb agx struts and granatelli lowering springs and now im getting a horrible clunking sound while driving,sounds like the strut assembley is loose.pulled the both front wheels off and check sway bar endlinks,lower 2 strut bolts,a arm nut and upper strut mount bolts and everything is tight.i havent pulled the struts out yet but the only other thing it could be is the nut that holds the strut mount to the strut is all the way tight.any suggestions
