"True" control arm length
Old Jan 1, 2007 | 12:22 PM
Adnectere's Avatar
Default "True" control arm length
This may not be the best place to post this, but I've been doing the example in Herb Adams' "Chassis Engineering" book to see if I grasp how the suspension is all laid out. BTW it is on an f-body of some sort, so I guess it fits this forum (and you guys are very knowledgeable). Does anyone know the difference between a control arm's length and it's "True" length? The "True" length is listed as being a bit longer than the physical control arm itself, which means it must represent some connection from different points. Thanks in advance.
