LCA Question?
Old Jan 6, 2007 | 01:30 PM
RGV SS's Avatar
Default LCA Question?
I've got a small issue. When going to the track I use 26 inch M/T drag radials with stock springs. Then when I come back from the track I switch to 18 inch Z06's with eibach springs. I go to the track maybe once every 2 months. So my question to you is: Do I need to get LCA brackets when ordering lower control arms, or will I be o.k. without them?
Old Jan 6, 2007 | 03:17 PM
GIJosh's Avatar
I`d certainly reccomend them. They made a huge difference in my cars launching ability. Even when you are running the stock ride height, put them SOB`s on the lowest setting, it really works! I use the Spohn Weld-ins.
Old Jan 7, 2007 | 08:46 AM
2_wacko's Avatar
If anything the LCAs are going to help you all around. It would be a good idea getting relocation brackets since your have the prokit.
