The Correct Way
Old Jan 18, 2007 | 05:36 PM
my number 1 hater's Avatar
Default The Correct Way
what it the correct way to adj a panhard bar on my 98 Z???
Old Jan 18, 2007 | 08:40 PM
soulless's Avatar
Depends, what kind of bar is it?
Old Jan 18, 2007 | 11:08 PM
Yahelou's Avatar
good question. was just about to ask that question too.
Old Jan 18, 2007 | 11:19 PM
kookamunga's Avatar
I just did it till the insides of the 315's diddn't touch the inner fender lol
Old Jan 20, 2007 | 07:02 PM
Yahelou's Avatar
does any know this one??
Old Jan 20, 2007 | 07:44 PM
soulless's Avatar
For one thing, it depends on what kind of bar it is. Are you wanting to know how to make sure the rear end is centered or just how to phycally adjust it?
More info needed!
Old Jan 20, 2007 | 10:23 PM
Yahelou's Avatar
well i have the umi single adjustable. i want to know how to center the rear end. I read about sprayin water on the road and measurin it. i cant do that cuz i live on a main road. and i also read about doing the string and the nuts. but i dont fully understand it. maybe someone can help me understand it better.
I hope im not hijackin the thread, but i want to install the bar tomm. but cant figure out how to do it the right way.
Old Jan 21, 2007 | 12:45 PM
soulless's Avatar
If your car is at factory ride hieght and you are not running 315s in the rear, just adjust the PHB to the same length as the factory part and bolt it in. Should get you pretty close.
I remember the thread about using the string and nuts to check to see if the rear end is centered. What it was saying is to use a string and weight to make a plumb. Tape the string to the fender and make sure the string is running down the center of the wheel, using the hub as the center point. The weight/nut must be positioned the same on each side to get a correct reading. You want the weight to be at exactly centered to the hub. Then you can measure the distance from the wheel hub to the weight, the distance should be the same on each side.
Here are some poor illustrations I made.
UMI makes to single adjustable PHBs, one is on car adjustable the other you have to remove to adjust.
off car
on car
Old Jan 21, 2007 | 12:49 PM
rk_2000_Z/28's Avatar
If you go to BMR's website they have an install section and there is instructions with some pics that shows how to adjust theirs. They recomend using a plumline.
Old Jan 23, 2007 | 05:33 PM
your not jackin this thread its cool.... i had alot of the same questions
L S 1 TECH RULES !!!!!!!!
Old Jan 23, 2007 | 06:09 PM
Yahelou's Avatar
that bmr website is actually a big help. i understand it now. I was making it harder than it really was.
