Can this be done?
Old Jan 19, 2007 | 09:39 PM
bigman's Avatar
Default Can this be done?
I have searched and found vague answers. I want to do the heater hose mod on a stock spring a strut/shock car. I am changing the struts/shocks to agx's tomorrow, but am leaving the stock springs the same. If i did the rear heater hose mod, will the rear look sagged? Because as it sits now, the rear has a big gap and the front is like half that. So i am hooping that it all looks even.
Old Jan 19, 2007 | 09:44 PM
Roadhouse's Avatar
If the rear is sitting higher than the front then it should level the car out some. The mod ought to drop the rear 3/4" or so.
Old Jan 19, 2007 | 09:48 PM
bigman's Avatar
cool, and do you know what size hose i need, i read that i need 3/8s and somewhere else it says 5.8ths.
Old Jan 19, 2007 | 10:25 PM
Roadhouse's Avatar
What I did is the 3/8" and wrap it up with electrical tape to make sure it wouldn't work itself out.
Old Jan 21, 2007 | 07:49 AM
subtlez28's Avatar
I did the hose mod like a week b4 I did the front lower perch. It looked WAY better w the front lowered also.
