LT1 brake conversion ?
Old Jan 19, 2007 | 10:40 PM
oange ss's Avatar
Default LT1 brake conversion ?
runnin LT1 rear brakes on my 01 Camaro, what all do i need to make the parking brake work ? just the cables ? all of them ? TIA
Old Jan 20, 2007 | 12:46 PM
CALL911's Avatar
Other than the location of the calipers on the rotor (front or back), aren't the rear calipers the same for the LT1's and LS1's??
Old Jan 20, 2007 | 03:16 PM
oange ss's Avatar
the parking brake mechanisms are different on the caliper
Old Jan 21, 2007 | 05:42 PM
JimboManJones's Avatar
I am almost positive you just need the parking brake cables, if you have everything else for the lt1 brakes, that is.
Old Jan 21, 2007 | 06:24 PM
oange ss's Avatar
do i need all of them or just the rear sections ?
Old Jan 22, 2007 | 10:35 AM
I am pretty sure all of them, may I ask why you are doing this? If your swapping in a lt1 rear, just swap the axles, its not hard to pull the axles out and swap everything over, lot easier then changing brake styles, I could make a write up for you on how to do it, its very easy.
Theres something about a drum in the ls1 parking brake that makes it different, I am not sure, I almost went through the opposite (lt1 to ls1) with a friend, so I am doing my best to help ya...
Old Jan 22, 2007 | 04:41 PM
oange ss's Avatar
using Lt1 brakes in the rear....i assuming the parking brake cable goin to the rear is the same, there's no really reason that should be different, i'm guessing the cables that split off that are different, LS1's use a shoe inside the rotor, where as the LT1 looks like it applys pressure to the piston using a lever arm setup...i guess if i had a picture of a stock LT1 setup it would help alot...thanx
