torque arm not ligning up!!!!!!
Old Jan 26, 2007 | 09:34 PM
Revelation Z28's Avatar
Default torque arm not ligning up!!!!!!
im putting my non adjustable UMI TA on right now, and i cant get the mother ****** lined pu at all to put the rear end bolts on. im putting the rear end side on first.
help!!!
Old Jan 26, 2007 | 10:04 PM
JonB's Avatar
I had to jack the rear end up some to get mine edlebrock to line up. You may have to mess around with it some I think I actually lifted the rear with the jack on the sway bar. You will probably also need to lift the rear to get the front mount back on as well.
Old Jan 26, 2007 | 10:12 PM
well i looked, and it looks like some of the rear end bracket welds are holding it up from lining up. im grinding a little bit off right now.
Old Jan 27, 2007 | 03:09 PM
i got the rear bolt on the diff housing in after 3 hours, but the front one didnt line up.
i dont know...
spend 9hrs on the dam thing total
