caliper bracket torque specs
Old Jan 29, 2007 | 08:39 PM
terr1bleone's Avatar
Default caliper bracket torque specs
one of my front caliper bracket bolts loosed up on the highway and fell off. i downshifted and coasted to a stop, then got a tow home. i got the new bolt and some locktite. what should i torque this to? i dont want this to happen again.
Old Jan 29, 2007 | 08:51 PM
Flawless02SS's Avatar
Just use some medium (blue) locktite and pull them down real good with a 3/8 drive. Should do the trick. That all I do, having locktite is the KEY !!
Old Jan 29, 2007 | 10:01 PM
SSmokin 01's Avatar
Caliper Guide Pin Bolt 37 lb-ft
Caliper Mounting Plate Bolt 74 lb-ft
Old Jan 29, 2007 | 10:33 PM
thanks smokin01 74lbs is a lot more then hand tight with a 3/8 drive. also using red locktite, im fine with having to heat them to get them out if need be.
