Cheapest shock to use with a Pro-Kit?
You want to lower the car, that means more spring rate and less shock travel. You can do it incorrectly (stock shocks, cheap *** shocks meant to be cheap replacements, or even nice quality shocks not meant for lowering springs, like Bilstein HD's). Or you have to realize you are changing a big part of the suspension and more spring/less travel means more spring damper, or "shock" is needed. Gotta pay to play if you want to end up with something that works the way it should.
I also didn't notice you have a LT1, and those springs are much stiffer than LS1 Pro-kits and you can forget about the SLP shocks even being ok.... You need Revalves or Koni's (Revalves are better here since that spring design doesn't allow access to the Koni adjuster. I'd recommend other springs for that reason, but also for the fact that lowering a car doesn't help the launching aspect at all.
My next step was shocks. I was thinking bilstein hd but i was told that i was basicly wasitng my money. But i bought them anyway and they were awsome, the ride comfort got much better and the handling and stability was much better to, so for the money the shocks were really good. I now that if you would have gotten the konis i´m sure it would be even better but i did not have the money to spend for those.
The pro kit is among the closest in lowering springs that has spring rate close to stock springs.....
My butt tells me that bilstein hd and work very good together with pro kit.
I´m sure there are better solutions but i think they were a very good improvment over stock.
If you want the best you have to pay for it........
So let's get the details right please or else we'll just confuse him terribly.
The other point is simple that Doski had stock shocks and HD's only, and certainly the HD's are better. But better doesn't equal right, and Bilstein's own catalog says that HD's aren't suitable for lowered cars. While he has the LS1 Pro-kits and those are about the only lowering spring HD's have even half a chance of dealing with over the short term, they are far from ideal. Hell, as soft as they are we're talking about front rates 25% more than stock and with a good 1" or more of lessened shock travel in which the shock has to do it's damping.
Hd's better than stock? Sure. Right, especially over the long term. No.
Dude...beg, borrow, work overtime, beg some more. Get the cash to do it right. An inadiquate suspension is not only annoying...its dangerous!!
These cars are fast. If you cannot lower it correctly, leave it stock until you can. The "look" will not be worth it if you crash it!
If that doesn't sway you....chicks hate shitty riding cars
i think if you called SAM he could better explain everthing.
However, that's like saying a size 10 shoe fits your size 12 feet better than a size 9 does. Might be better, far from what it should or could be.
Do I just scrap everything and start over? Do I get the Koni SA's and change the wheels to an 18 inch, or yikes a 17 inch for bigger sidewall? Cash is not an issue, but I don't want to throw it away either...
Thoughts? Thanks.
Thoughts? Thanks.
wow.. Do I just scrap everything and start over? Do I get the Koni SA's and change the wheels to an 18 inch, or yikes a 17 inch for bigger sidewall? Cash is not an issue, but I don't want to throw it away either...
Thoughts? Thanks.
wow..You BOTH need to give Sam a call.
