Questions about LCA
Also, I would say that the majority of F-Body's would be off a small amount, just like the majority of them do not sit level from side to side. It's just part of the mass-production process... Each car is going to be different.
Was your car ever in an accident that you know of? How does it drive after the alignment? My gut feeling is, if the car has not been in an accident, and it seems to drive OK (ie, you're not correcting the wheel all the time as you're going down the road), you shouldn't worry about it IMHO.
Hope that helps...
https://ls1tech.com/forums/showpost....00&postcount=5
) with a -0.24° thrust angle and ~60" track-width on the back of the car, the driver-side tire on your car is about ~1/8" back, and the passenger-side rear tire is ~1/8" forward in relationship to the front wheels, or about ~1/4" off in total. That doesn't really sound unreasonable, but I can't find the spec at the moment. But, as VIP1 has stated, with adjustable LCA's, you could probably get that to zero. I guess the next question is whether it's worth the money & time to do that if it is indeed out of spec. I think they compensate with the front-toe settings when the rear is non-adjustable.Your car is the opposite of this diagram - It depicts a positive thrust angle:
