quick question on brake caliper
The down side is a stock F-Car rotor is significantly thinner than a C5 rotor. So the caliper is wider between the piston face and the outer ears to accommodate the thicker rotor. Put a thinner rotor in there and the pistons move further out of the caliper in order to engage. Only a problem if you run cut rotors and ewaer pads to the backing plates.
