How to Install a K member...
Old Feb 19, 2007 | 10:54 AM
connexion2005's Avatar
Default How to Install a K member...
I will be swapping out my K member with one that isn't bent due to hitting a curb. What do I do to perform this...can someone give me a decent write up...please!
Old Feb 19, 2007 | 11:09 AM
cwaldt's Avatar
I would support all 4 jack points with jack stands or blocks.
Support engine with an engine hoist by using an engine leveler to attach to the engine.
Take rims and tires off.
Unbolt rack and pinion from the k-member and the connection points on each side.
Unbolt the shock towers ( 4 bolts each side)
Unbolt the brake line that runs across the k-member
Unbolt the motor mounts from the engine
Unbolt the k-member from the car. (3 bolts on each side)
I think that should take care of you. I don't think I left anything out. The engine hoist and tranny mounting points should be enough to hold the motor in place.
Installing new K-member I'd bolt up to the motor 1st and then bolt up to the frame rails of the car.
Good Luck
Old Feb 19, 2007 | 04:15 PM
C Murda's Avatar
good info. i think ill be ordering mine this week and didnt want to have to pay someone to do it.
Old Feb 19, 2007 | 04:19 PM
C Murda's Avatar
what points on the motor should the leveler be attached?
Old Feb 19, 2007 | 09:52 PM
thanks a ton...that seems like a great write up...would this be a good time to do motor mounts as well?
Old Feb 19, 2007 | 10:56 PM
99huggercamaro's Avatar
yes, and u will need an alinment too i believe.
Old Feb 19, 2007 | 11:40 PM
brandonppr's Avatar
I just put some bolts in the heads and hooked the hoist to the bolts with a chain.
Old Feb 21, 2007 | 01:32 AM
GDM Z28's Avatar
im doing my k member now....i just unbolted the a arms and now the a arms are being a PITA....its a tubular bmr k member with stock a arms....any one have any tips or tricks?
Old Feb 21, 2007 | 11:07 AM
cwaldt's Avatar
Are you to the point of putting everything back in? If you are it is a pain to do that by yourself. I had mine bolted to the k-member and then lifted the shock tower up and ran the bolts thru those 4 holes I've done it by myself but most of the time I had my wife come out to the garage and put a nut on on of the bolts for me.
Old Feb 21, 2007 | 12:26 PM
GDM Z28's Avatar
So its easier to bolt the a arms to the k member then lift the k member up cause im about to rip my a arms off and burn them.
Old Feb 21, 2007 | 02:52 PM
cwaldt's Avatar
If your just changing the k-member I'd mount it first. After you mount the K-member mount the a-arms to the k-member and then you can push the shock tower up and mount it to the car..
Old Feb 21, 2007 | 03:24 PM
GDM Z28's Avatar
i have the k member bolted to the car but for some damn reason i cant get the a arms to go into place.....i think a tank of gas and a lighter will come in handy now
Old Feb 21, 2007 | 08:49 PM
3.4camaro's Avatar
happened to me a couple weeks ago. push like a ************ and dont let up. have somone physically weaker than you help, so you can thank them for helping you and then push them on the ground, because they are weaker.
Old Feb 22, 2007 | 01:46 AM
GDM Z28's Avatar
i got it tonight...its so much ******* easier to take the k member out...put the a arms in then push the k member up. BTW how off was all of your alignments after doing a k member? mine is really off lol
Old Feb 22, 2007 | 06:54 AM
cwaldt's Avatar
Glad you got it mounted. I never thought of this route because I had my BBC attached to the K-member when I mounted mine. There wouldn't have been any pushing on the K-member for me.
My alignment wasn't too bad. I adjusted everything as much as I could to get the tires as close to straight as possible. I'm going to take it to an alignment shop soon.
Old Feb 22, 2007 | 08:48 AM
GDM Z28's Avatar
my passanger side isnt that bad but my driver side is cambering like a ****.....time to play with it a bit
Old Feb 22, 2007 | 08:49 AM
GDM Z28's Avatar
BTW ty for your help man.....it helped a lot
