alignment on a 4-link
Old Mar 4, 2007 | 04:17 PM
eLTwerker's Avatar
Default alignment on a 4-link
How is alignment done on a 4-link front suspension? I know caster/camber plates are used on 3-link fronts, but I don't know how its done on 4-link set ups.
Old Mar 4, 2007 | 09:55 PM
trackbird's Avatar
Castor/camber plates are used on strut type suspensions. It's not really a "link" (that's the rear). The shock style setup we have with coil springs over the shocks and upper and lower control arms is adjusted by moving the lower control arm. The mounting locations in the K member are slotted to allow you to pull the arm in and out to adjust camber and you can rotate it forward and back (the rear mount is slotted to allow the arm to rotate in place) to adjust castor.
