Rear Rotor Tips
Old Mar 5, 2007 | 08:41 PM
cold_surfer's Avatar
Default Rear Rotor Tips
I'm new to the forum and was looking for info/tips/tricks when replacing the rear rotors and pads. I'm going with wagner rotor and AC Delco Ceramic pad. 67K on the factory setup-- still there intact but kinda groovy.
I see there is a brake drum inside the rotor. Is there a trick to getting the rotor off the car (like turning a dial/screw/adjuster)? Do I have to manually adjust the rear parking brake again once it is installed? I've used my parking brake about every 90 days here in florida and it works good (shouldn't be rust issues on it). Thoughts? I've put off changing them because of the drum, but now they are really wavy....
Thanks,
Tony
2002 TA SLP cold air induction, $6 resistor installed/removed, K&N, auto,
Convertible
Old Mar 5, 2007 | 08:52 PM
bene's Avatar
Trunion King
Wheels off, 15 mm bolts off, rotors off, pads off. Installation is reverse. BTW, you might need a rubber mallet to get the rotors off. Sometimes they get stuck on the axles.
Old Mar 5, 2007 | 09:46 PM
SCRWS6
Guest
Posts: n/a
^ and watch out for the little flexi screw on retainer thats on one of the bolts....or at least was on mine.......
Old Mar 5, 2007 | 10:06 PM
scrws6,
does that mean have a back-up car to run for parts in case it gets messed up..?
Thanks,
Tony
Old Mar 7, 2007 | 04:45 AM
02Z28LS1's Avatar
Originally Posted by cold_surfer
scrws6,
Thanks,
Tony
no...one some cars, there is a little "star washer"-looking retaining clip that fits over one of the lug bolts, so that when the calipers are removed, the rotor doesn't slide off on its own and fall to the ground (or on your foot).
it's not a necessary piece in any fashion, so if it gets messed up, just leave it off....i did
Old Apr 29, 2008 | 03:13 PM
13brian's Avatar
I think that retainer is actually on there for ease of assembly at the plant(s).
