Still have the same brake problem, please HELP
I have relpaced rotors, pads and flushed the system completely twice. The first flush there was air in both rear lines, the second time there was only air in the right rear. No air was in the front lines at all.
The issues I am still having are spongy pedal/loss of braking force after steady braking from 70mph + and the car pulls to the left under moderate braking.
Normal driving at slower speeds the car brakes fine, it's really noticable braking at high speeds under moderate to high braking, every time.
There are no leaks or puddles that can be found, used a pressure bleeder to bleed the system and the pressure held. So if anyone has any ideas on what could be wrong I would greatly appreciate it. Thanks.
I am posting this in different forums to better my chances of finding the problem.
If you have moister in the caliper, it will boil and create water vapor. Vapor is compessible and will give you the spongy pedal after a hard stop. Maybe water is getting is a bad piston seal??
good luck.
