QA1s squeaking noise
Old Mar 19, 2007 | 11:00 AM
CRZYPWR's Avatar
Default QA1s squeaking noise
I don't know what the deal is, I installed a brand new pair of QA1s on the rear, and they're set to mid setting, pretty stiff. When I drive around on a little bumpy road and the car starts to bounce a bit is makes a squeaking noise. Anyone experienced this?
Thanks
Old Mar 19, 2007 | 01:49 PM
blackbyrd's Avatar
front or rear
if its the rear check the bushings where it goes through the body one of mine slipped over the bolt because i forgot to put the washer on.
if its from the front i dont know i havent installed mine yet
Old Mar 20, 2007 | 02:10 PM
2001z's Avatar
make sure you put the spring in correct. If it isnt sitting right it will squeek.
