LT1 TO LS1 front brake conversion question???
Old Mar 19, 2007 | 06:54 PM
transmaro93's Avatar
Default LT1 TO LS1 front brake conversion question???
Besides.. the calipers, spindles, roters, pads, is there anything else i would need... can i use my stock upper A-arms and stock brake hoses and hardware???... thanks in advance guys..
Old Mar 19, 2007 | 08:32 PM
76LS1BIRD's Avatar
Restricted User
You should get hoses from a LS1 car.
Old Mar 19, 2007 | 08:59 PM
Hot Copper Z's Avatar
Definitely use the banjo bolts for the hoses from the LS-1 calipers,they are a different thread.Everything else you have listed will work.
Old Mar 19, 2007 | 09:58 PM
Rocko71's Avatar
If i remember correctly, you also need the little brackets that hold the hose to the k member from an ls1 car. It seems like my lt1 brackets wouldnt fit the ls1 hose angle right or something... I just remember having a problem with that.
Old Mar 23, 2007 | 04:08 AM
JasonWW's Avatar
Don't forget the PABs.
Have you ruled out the C5 kit? It would probably be cheaper.
