Whats the difference...
The 1LE is a whole package. The springs are firmer, A-arms, rear control arm bushings and PHR all use a firmer rubber bushing. I can't remember about the shocks, they may have been Bilsteins. Anyway, there is a whole section on the 1LE cars. I'm sure those guys can tell you all the little details.
I know at one point the 1LE was a police or race option that deleted the A/C and added bigger brakes as well as a lot of suspension related upgrades. It's just that these options change over the years.
Check here:
http://www.transamworld.com/fbird-history-php4.php
It shows only 14 cars built in 97 with the 1LE option.
'96-'99 1LE have Koni double adjustable shocks, the WS6 had special DeCarbon shocks. They both share the same springs, sways (19mm rear, 32mm hollow front), rear control arms and PHB. 1LE cars also got a better trans mount and front LCA bushings. 1LE Z28's got 16" wheels and 245 tires like all Z28's (that are not also SS), and all WS6 got 275's on 17" wheels.
In 2000 there was no 1LE option available. In early 2000 GM stopped putting the 1LE springs, LCA's, & PHB on the WS6, and the parts are the same as a base Formula/Z28. So most 2000 and all 2001 and 2002 WS6 only have an upgraded front sway bar over a base T/A or Formula.
'01-'02 1LE cars were an option on SLP built SS & Firehawks. The front springs were the same part number used on '93-'97 1LE's, and the rear springs were unchanged (base Formula). SLP installed a 21mm rear bar (previously only used on the '93 1LE), and their 35mm hollow front bar. Shocks were still Koni DA's.
EDIT: I own 1le.net, and plan to put it back up this summer. Money is tight, and some file corruption is going to take me hours to resolve, and I am lazy.
