Trak Pak= ???D.S. loop
Old Mar 27, 2007 | 08:26 AM
Stang's Bane's Avatar
Default Trak Pak= ???D.S. loop
If you are running a BMR Trak pak, what DS loop are you running??
Old Mar 27, 2007 | 08:41 AM
BMR Suspension's Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
We sell a weld in kit for that particular arm just give me a call
Lee Spicher
lee@bmrfabrication.com
(813)986-9302
Old Mar 27, 2007 | 09:00 AM
Cool, I had a few ??'s about my trak pak anyway. Like, why does is my crossmember straight rectangle tubing and every other one I have seen has a round one with a bend in it??
Old Mar 27, 2007 | 08:33 PM
Penz's Avatar
Is there any option besides welding? I am trying to stay away from having to do that. Also, wouldn't I have to pull the part of the carpet when I have someone weld a loop in?
Old Mar 28, 2007 | 08:07 AM
The Trak Pak crossmember crosses where the floor mounts are for the driveshaft loop. The only way to be able to attach one is for you to weld it to the crossmember. You will not need to remove the carpet to add on the loop.
Lee Spicher
(813)986-9302
