brake lines
Old Apr 6, 2007 | 06:33 PM
blackbyrd's Avatar
Default brake lines
k did a search really didnt find the info i was looking for
im swapping engines in my car and i dropped the k member to do it and what i was wondering is should the brake lines be changed out. not for a performance upgrade but for peice of mind. not the hard lines but the ribbed metal tubing that is semi stiff but can be bent a little.
when i took the k member out i had to bend some of the tubing to drop the engine so i was just wondering if while i had it out and had full access to all of it shoud i change it. i know people have replaced the rubber part on the caliper with braided steel lines but i was just curious about the other?
