lowering question
Old Apr 20, 2007 | 07:37 AM
2fstws6's Avatar
Default lowering question
I am buying the QA1 r coil over for the front do 1.5 inch drop with the 300 rate springs.For the back I was thinking about just cutting one coil out for a 1 inch drop.My question in the back I have a BMR non adjustable tubular chrome moly control arms and panhard bar with poly bushings.With a 1 inch drop in back will I be ok with the non adjustable.I also have a 12 bolt and BMR a adjustable tranny tail shaft mounted mounted torque arm.
Old Apr 20, 2007 | 02:28 PM
5301113's Avatar
I wouldn't cut the coil that will change your spring weight and make the car bounces and unsafe to driver hard . I think you would have to buy adjustable mods because you changed your angles and clearance.
Old Apr 20, 2007 | 02:58 PM
2fstws6's Avatar
I read somewhere it would change the rate from the stock 114 to 130. If that is true that does not sound to bad ?
