Removing and replacing spindle???
Separating the knuckle from the ball joints is the toughest part.
Set the bottom in first and then put a jack under the a-arm to raise it to the upper ball joint.
Curious where you the replacement?
These knuckles are just cast metal and not strong when impacted from the outside. About 1/2 the used ones I've bought have been bent or tweaked.
Just a precaution ...
