multi purpose shocks
Riding great is in the eye of the beholder. I certainly do not agree they are anything special for ride. Though compared to the not so right stockers with a lot of miles on them, they can look pretty good.
*IF* QA1's and KYB AGX's were the only two shocks on the fact of the planet. I'd be running AGX's. Thankfully that's not the case.
While I agree that there is no perfect answer for drag and handling, it's much more feasible to launch a car that handles well than it is to get a great launching car to handle and drive well. If for no other reason than drag racing mimics NOTHING on the street. Drag strips aren't usually bumpy. Real-world driving requires turning more than getting onto the return road. Fact is the dynamics involved in handling, ride and stability are more similar between autoxing, road-courses and the street than the drag strip is with the street.
I'm also not saying anyone has to build a "road-race" car, no am I advocating it. Frankly too many folks lower their cars (based only on looks) who drag race all the time. Gee, they're willing to make that sacrifice (lowering and heavier springs aren't as good @ transferring weight)..............
And to close. Just because Bobby-Joe can't cut a 1.9 on Koni's doesn't mean he'd be able to on QA1's either. That point has been made time in and out. And if you turn the front Koni's way down, they have rebound similar to stock shocks and HD's. Yes, more than QA1's, and QA1's are DRAG shocks, that's what they do. There's a reason you see some fast old stuff on 30 year old stock shocks. I'm sure there's a local Nova or something on junk shocks, because they are trash, have no damping and transfer weight. That's what drag shocks do. That's NOT what street shocks do (or are supposed to). Koni MAKES drag shocks, and they are so different that there is a BIG disclaimer stating that they should not be used on the highway or personal injury can result. So who's wrong?
If you want a drag shock, fine. If you want the car to handle and work correctly, fine. But don't tell me that QA1's are in any way, shape or form even on the same level as Bilsteins, let alone Koni's.
Please realize that the damping reflected here is not correct for an F-body.
The issues on the QA1's was that you were getting a lot of stiction on the bump side, along with huge changes and huge amouts of bump damping. And the rebound damping curve was a wacky combination of progressive and digressive, and what's worse is that as the damping increased (the orange line for instance) the rebound curve got even more messed up. Softer in the very low-speed range, stiffer up high.
You don't want or need equal amounts of bump vs. rebound, that just wrecks the ride and tire compliance. Bump is only there to control the unsprung weight, which is much less than the sprung weight of the car.
Those curves are a mess, Frank and I complete agree on that. As it shows, there is too much bump when you get any amount of rebound to damp the car correctly, and there is ALWAYS way too much stiction in the shocks on bump. I'll add that not being gas charged shocks makes them much more prone to shock fade with heat, which means those curves an hour down the road wouldn't be the same, especially the hotter the weather.
