Brake Bleeeding??
Old May 10, 2007 | 09:03 PM
02BEAST's Avatar
Default Brake Bleeeding??
Hey guys I want to do new rotors and pads what size rotors can I go with I have 18" wheels I think factory rotors are 12" and also when I do rotors and pads do I need to bleed the brakes?
Old May 10, 2007 | 09:24 PM
blownta00's Avatar
u can always bleed your brake but its not necessary unless u change calipers, lines, or hoses
Old May 11, 2007 | 08:48 AM
VIP1's Avatar
Copy & Paste Moderator
https://ls1tech.com/forums/showpost....91&postcount=5
Old May 11, 2007 | 01:13 PM
z28bryan's Avatar
I believe you need to use stock size rotors, which are sufficient enough for even track use with a good rotor. Unless you went with a different bigger brake kit like a C5, C6 or other kit.
You don't need to bleed the brakes but its worth doing after a rotor and pad change so you can really feel the difference.
Old May 11, 2007 | 03:09 PM
02BEAST's Avatar
How do I bleed the brakes never done it before?
Old May 13, 2007 | 06:47 PM
02BEAST's Avatar
Anyone?
