abs inop
Old May 14, 2007 | 04:04 PM
Doski's Avatar
Default abs inop
My abs inop light is on, when i check it it says c0036 Left rear Tone wheel
What does it mean?
Old May 14, 2007 | 10:11 PM
VIP1's Avatar
Copy & Paste Moderator
Check the sensor at that wheel.
Old May 17, 2007 | 03:54 AM
Doski's Avatar
Where is the sensor located and what does tone wheel mean?
Old May 17, 2007 | 07:48 PM
VIP1's Avatar
I'm not completely sure, but it should be behind the rotor (you may be able to see it looking at the back of the wheel assembly without actually removing it from the car). If I remember correctly, the tone wheel is a toothed wheel (like a large gear) which the sensor reads. Typically there isn't anything wrong with it, but the sensor or may have some grime build up causing a bad reading. I'm going from memory here since I've never looked for it on a f-body.
Old May 17, 2007 | 08:19 PM
LowBird's Avatar
also check/ clean the bulkhead connector going to the rear end. i had one plug come out after a dyno run
Old May 17, 2007 | 09:45 PM
SJM Manufacturing Inc's Avatar
The tone wheel is known on these boards as the reluctor gears. It is the gear that alters the sensors signal frequency.
Old May 18, 2007 | 06:30 AM
Doski's Avatar
Ok i probobly have to clean it then.....were is it??
