Brake line help!!
Old May 16, 2007 | 01:37 PM
Stang's Bane's Avatar
Default Brake line help!!
I need to know how long one of the rear brake lines on a ls1 car is and what types of fittings. I know one end is a banjo fitting, what about the other?? 3 channel car..
Old May 16, 2007 | 08:20 PM
1 FMF's Avatar
i have traction ctrl but the lines from the chasis bracket to the caliper should be the same. my oem line is like 7", the new one i got in the russell kit for a 2002 camaro measures 8" from center of hole in banjo to end of fitting on other end. It's banjo fitting on the caliper end, 10mm x 1.0 bolt goes into caliper. Other end is a straight end, female fitting that's also 10mm x 1.0.
Old May 16, 2007 | 09:07 PM
Thanks alot man!! I just need to find someone to sell me 1 single line now
Old May 16, 2007 | 11:52 PM
1 FMF's Avatar
how much do you want to pay?
i'm hoping to finish my little brake project by this weekend, if you can't find a single rear brake line by then I may be willing to sell you mine. It's an oem hose, nothing wrong with it.
Old May 17, 2007 | 06:59 AM
I have a braided hose kit that is missing one of the rear lines and I need a braided line. Thanks anyway!!
