Trick Springs???????
Old Apr 30, 2003 | 06:48 PM
ChazLS12002's Avatar
Default Trick Springs???????
Moroso makes a pair of Trick springs, which I was wondering what makes these different, why are they called Trick Springs? and are they for a daily driver???
Any info would be appreciated!!!!!!!!
THANKS ALREADY
Old Apr 30, 2003 | 08:55 PM
trackbird's Avatar
Default Re: Trick Springs???????
This is from Morosos catalog.
Moroso "Trick" Front Springs are designed for maximum weight transfer. Trick Front Springs are tall, small wire diameter coil springs that hold a great amount of stored energy for instant weight transfer. Listed below are springs that have been computer designed for the specific applications indicated. Each spring is the correct rate for the particular application and, in most cases, may be installed with no modifications.
It may be necessary to modify the springs to get the desired front end height. If the front end is too high it may be lowered by cutting off one-half of a coil. Many factors affect the front end height. Wheel offset is a major consideration. A front wheel offset to the outside will increase leverage of the lower A-frame against the coil spring, and the nose of the car will be lower. Disc brake spacers will further affect the height. Adding or removing as little as 50 lbs. can also make a big difference in front-end height. Take this into consideration when adding a fiberglass hood, aluminum heads, or when putting the battery in the trunk. Although these changes will affect the height of the car, the spring rates will be unaffected as long as you stay within the guidelines of our definitions. Sold in pairs.
IMPORTANT! For drag racing only; NOT for street use.
Old May 1, 2003 | 12:30 AM
Robzilla's Avatar
trackbird, how come your not a mod for the handling in braking section, you answer everyone's questions and you do it in great detail
i know who to come to if i ever have a question about suspension stuff
but anyways keep up the good work
Old May 1, 2003 | 07:18 AM
trackbird's Avatar
You'd have to talk to PSJ about that one (the Mod).
I guess I have too much free time these days (if I'm not working on sombodys race car or autocrossing).
Kevin
