ABS problem...?
Old May 3, 2003 | 12:38 AM
BriguyLS1's Avatar
Default ABS problem...?
I have a problem with my ABS sensors and it kickes on all the time even when its dry out...? how can I fix it? and where can I get the parts?
Old May 4, 2003 | 08:52 PM
trackbird's Avatar
Default Re: ABS problem...?
It "kicks in everytime".....is your ABS inop light on? Are you running the same size tires on all 4 corners? Are you getting a constant pulsing in the pedal (like a soft ABS function)? Any extra info is helpful.
Kevin
Old May 5, 2003 | 09:33 PM
BriguyLS1's Avatar
Yes, the low traction light does show on the dash.. it seams to only do it when comming to a stop from low speeds... but when it is completly dry out... also I am running the same size tires on all 4. let me know what ya think.
Old May 5, 2003 | 10:46 PM
xaon's Avatar
My car also does this exact same thing, though after a while mine will go ABS InOp. Then it doesn't do it anymore
Mine started right after I put my moser 9" in, we managed to tag one of the sensors with the welder though, so I hadn't pushed the issue since I'm too lazy to re-splice in some new wire. (Covoluted Tubing + Sparks == Instant Flame)
Old May 5, 2003 | 10:50 PM
trackbird's Avatar
I'd suspect Xaon just hit the nail on the head, I'm guessing you have a bad sensor or bad wire to a sensor or a bad connection. I'd start there and see what you find. Let usknow if you make progress or have any questions. Good luck.
