Need some quick help, ASAP!
6. Grab a grease gun and grease each end of the panhard bar. Be careful not to put too much grease into the ends (see Figure 3). Two or three pumps of the grease gun should be sufficient. If you start to see the bushings pop out you know you have way too much grease in there. You will need to grab a 5/16” wrench/socket and unscrew the fitting and let the grease work its way back out. I used a marine grade grease recommended to me by Brett Rockey, owner of BMR Fabrications, for its excellent water resistance and stickiness.
Step 5 was to tigthen the bolt to the proper specs (61 ft/lbs) and I've already done that, so my PHR is just sitting there waiting for grease. I found the "fitting" where the grease will "work its way back out" but where do I squirt the grease into to start with? I can't seem to locate any other spot in which to squirt the grease into. Any help would be appreciated!
