brake ?s
and on inspection both front rotors are scored on the inside and not the outside. I am going to do pads and rotors. My question is shall I install
new calipers? Thanks for any reply.
but whether you need or should replace the calipers depends on a few things-
how old and how many miles you have on the car,
what kind of driving you did or plan to do,
were the brakes ever bled,
at least inspect and regrease the slide pins, and inspect the rubber boots around the pistons. I just did my brakes and i have 37k miles on mine but i know i didn't have any problems. in your case, unless you know for sure the cause of your problem don't assume the calipers are 100% functional and risk another set of rotors and pads. Pop the pistons and inspect them and the caliper, otherwise just spend the $80 on new front calipers.
