SFC Installed New Noise!
Old Jun 26, 2007 | 01:35 AM
six8fbird's Avatar
Default SFC Installed New Noise!
Just installed the BMR Tubular SFC and was thinking it was gonna get rid of all my rattles and shakes in my 01, but instead it magnified a creak that comes from the rear of the car. I have narrowed it down to a suspension part cause it only makes noises when I push the body side to side, any suggestions on what it might be? I know there can be lots of possibilities here but any help would be great?
Old Jun 26, 2007 | 03:00 AM
revtime's Avatar
Sounds like one of your poly bushings in the rear components is squeaking.
Lube it up.
Old Jun 26, 2007 | 04:00 AM
ErikElvis's Avatar
I agree. If you have polys shoot some grease in em. If it doesnt help go through the back and make sure things are torqued correctly. What kinda panhard bar?
Old Jun 26, 2007 | 07:58 AM
DuronClocker's Avatar
I'm going to take a stab and say its an LCA bushing One of mine squeaks too
Old Jun 26, 2007 | 08:15 AM
BMR Suspension's Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
I would check the lower control arms. It's common for people not to get them tightened properly after a subframe connector install.
Lee Spicher
lee@bmrfabrication.com
(813)986-9302
Old Jun 26, 2007 | 01:24 PM
six8fbird's Avatar
90 ft/lbs right for the LCA? Also I did grease the LCA but stopped cause they started to bulge out on the outer ends, what does that mean (noobie)? yeah I have the stock pan bar. Gonna order a adj one here soon. Thanks guys
Old Jun 26, 2007 | 02:01 PM
RA4926's Avatar
side to side would be panhard bar...does it sqeak if you push down on the back of the car?
Old Jun 26, 2007 | 02:04 PM
six8fbird's Avatar
no it does not make any noise if I push down on the car, only side to side.
Old Jun 26, 2007 | 02:06 PM
RA4926's Avatar
sounds like bushing squeaking or something else?
Old Jun 27, 2007 | 07:48 AM
Sometimes you might have to go higher then the normal torque value to get proper crush on the lower control arm inner sleeve. I normally only recommend 2-3 pumps on the grease to lube the bushings. If you over grease the bushings it will cause them to balloon (like you described) and possibly cause premature bushing failure.
Lee Spicher
(813)986-9302
