1LE swaybar
Old May 8, 2003 | 08:55 AM
CamaroSS3725's Avatar
Default 1LE swaybar
Is their an advantage in using a 1LE front swaybar over the stock swaybar or should I go with a aver market one?
Old May 8, 2003 | 01:17 PM
Viper's Avatar
Default Re: 1LE swaybar
Stock is 30mm, 1LE is 32mm, S/T makes a great one at 35mm. The advantage is better turn in.
Old May 8, 2003 | 05:06 PM
Xsta Z 28's Avatar
My 2002 1LE is 35 mm.
Old May 8, 2003 | 07:13 PM
xaon's Avatar
The 35mm '1LE' swaybar was a seperate option offered by SLP. The standard 1LE swaybar is a 32mm.
SLP's 35mm costs 500 bucks, S/T's is like 100-150.
To answer your question, yes the 32mm 1LE bar is a good replacement for the stock front bar. It's pretty cheap too.
Old May 9, 2003 | 08:13 AM
Caswell's Avatar
The front sway bar on the 2002 SS is already 32mm.
