PHB questions?
Quote:
About the PHB, should I get it single adjustable or with double adjustments?
Either, both will do the job. Consult with your wallet and decide how much lighter it should be and order accordingly (not really a wrong answer on this one).
Quote:
How come they make them in two different ways? Whats the purpose of each of them?
Like the control arms. If it has heim joints or rod ends on it, they have to mount somehow and they usually screw in. it is just a way to attach them (and it keeps the control arms and panhard rod using the same parts to assemble them....saving money. The new BMR adjustable with poly/poly bushings has a single adjustment in the center.)
Quote:
Does BMR or Hotchkis make a good one? Do they offer theirs in different ends?
BMR has a heim/heim and poly/poly adjustable, hotchkis has a poly/poly that is not adjustable.
Quote:
Which ends should I go with on the PHB?
It is not as critical (to prevent binding) as the control arms, poly works fine. Rod ends are more positive, but may border on overkill.
Quote:
You say that youre going to change over to the LG LCAs, why and what are you running now?
I have BMR Heim/Heim control arms and panhard rod. I had some Herb Adams heim/heim lca's and they didn't make nearly the noise that my BMR lca's make (rattling and noise). The LG Motorsports seem to be much quieter, I thought I'd try them....in the name of science.
This may help out.....
If you are autocrossing on sticky tires, the heim joints will locate the rear end a little bit better. There is virtually no play in them, poly still can give a very slight amount. The only thing the heim joints may help is to prevent the tires from rubbing the inner fenders. The difference will be small....
