How to get more responsive steering?
Id love to have an easy turning wheel, but I just dont know how.
TTT for ya.
The pump already pushes 3 times the amount of fluid the rack needs to operate. Thats why people get underdrive pullies (don't pump so much to keep from burning up). Also there is a modified pump around that reduces the amount of fluid even more to save power and run cooler.
To make the "rack" faster, you would have to change the internal ratio (pinnion to rack ratio). Also, power steering racks already have faster (not easier) ratios than manual racks. The manual rack has a higher ratio (more turns lock to lock) to make up for not having the power assist.
alignment will make it more responsive.....so will rod ends on everything and making the car light...
if you want it "easier" to turn....
1) get smaller tires on the front (won't handle but will be "easy" to turn)
2) lighten up the front end (good for more than just turning...).
One thing that did help some was a different steering wheel. By giving up the air bag, it reduced weight (to turn) and made it a little easier.
