Drive Shaft Loop
Old Jul 27, 2007 | 12:56 AM
SuperZ's Avatar
Default Drive Shaft Loop
What are you guys running for them???Any pics?? I bought the Jegs one for our cars and it is made nice but did not fit or come close to fitting under there....
Old Jul 27, 2007 | 01:28 PM
SuperZ's Avatar
any body??
Old Jul 27, 2007 | 01:46 PM
koolaid_kid's Avatar
I have a BMR unit. It fits fine. There is really nothing to see except a loop that you run the driveshaft through, and it has 2 bolts on each side bolting it to the body.
Where does yours not fit?
Which model was it (part #)?
Old Jul 27, 2007 | 02:28 PM
T-hawk's Avatar
Are you sure you are putting it on right?
With the torque arm, drive shaft, and exhaust all sharing space in the trans tunnel there is only one right way to install the loop. If you tried to put it on rotated 180 degrees off then it won't fit... Another thing to consider is that its only made to fit a car with components that run in the stock locations. With that list of mods in your sig. you might be out of luck with it fitting if you have changed any of the stock driveshaft diameter, exhaust diameter/location, and torque arm design.
Otherwise are you sure they sent you the right one?
Old Jul 27, 2007 | 03:28 PM
SuperZ's Avatar
its that one.Ill have to mess with it some more but i tried it all different ways just because it wouldnt work.
Old Jul 27, 2007 | 04:20 PM
JEB99TA's Avatar
I have the BMR and had to do the 5lb hand sledge mod to get it to fit ... and it BARELY fits. It's becasue my exhaust is MAC 3/4 length headers with the MAC ORY Flowmaster merge collector welded in the ORY for better flow. If I had LT's and regular ORY, the BMR would fit perfectly ... and it's more an oval shape instead of a true round opening ... if you don't get yours worked out, go with the BMR.
Old Jul 27, 2007 | 04:51 PM
cptncdy's Avatar
BMR worked fine for me
