easy LCA installation question
Old Jul 27, 2007 | 09:30 AM
oneBADDz's Avatar
Default easy LCA installation question
Picked em up used REALLY cheap so I don't have instructions, does the greasable end go to the front or the rear. Thanks
Old Jul 27, 2007 | 09:42 AM
LilSlo1's Avatar
They should have grease fittings on both ends.
Unless of course that's why there were so cheap.
Old Jul 27, 2007 | 09:54 AM
oneBADDz's Avatar
I've seen plenty around that aren't greasable at all. I don't mind them not being greasable on both ends, I didn't really want any LCAs at all at the moment, just couldn't pass up the chance to see how I would like the poly bushings for this cheap
Old Jul 27, 2007 | 10:59 AM
2_wacko's Avatar
If you can post a pic we can help you a little better.
Old Jul 27, 2007 | 01:18 PM
OldeSkool's Avatar
the front, the part that attaches to the body is the critical point in keeping noise out of the inside of the car. So if its poly/rod... poly goes body side.. poly/rubber, rubber goes body side.. if its poly/poly and is only half greasable, I would put the greased end in the body.
Old Jul 28, 2007 | 12:47 AM
oneBADDz's Avatar
Thanks guys, they are poly/poly. I put the grease fittings on the body side rather than the rear end. Noise in the cabin is already rediculous, I just finished putting in lightweight Ozite carpet without insulation
