brake piston
Old Aug 9, 2007 | 09:11 AM
qwikz28's Avatar
Default brake piston
how do i release the piston while changing brake pads. i tried using my palm which i thought was supposed to work but so far no dice...
Old Aug 9, 2007 | 11:17 AM
98redM6's Avatar
What I do is usually grab the brake pads you are replacing and use them along with a c clamp to push the piston back in. Either the pad will work or some piece of metal or wood. If you're doing dual pistons make sure you distribute the pressure equally so that the pistons don't get stuck or damaged.
Old Aug 9, 2007 | 01:01 PM
qwikz28's Avatar
hmm i'll give that a try. i was always under the impression that they recess by hand. i suck
Old Aug 9, 2007 | 07:42 PM
VIP1's Avatar
Copy & Paste Moderator
http://www.installuniversity.com/ins...ds_mwarren.htm
Old Aug 9, 2007 | 10:56 PM
qwikz28's Avatar
hmm.... i browsed through install university this morning. i can't believe i missed that. thanks for the link but i got the c-clamp this morning and everything was good as new. thanks again guys
