Lowering car and Alignments
Old May 26, 2003 | 12:57 PM
00NBMCamaro's Avatar
Default Lowering car and Alignments
just lowered my car with eibach pro kit. looks nice.. anyways needs to be aligned. pulls bad to the right.. i hear people all the time talking about getting the alignment set the way you want it. i have never got an alignment done on a car and the specs are new to me
should i just get the stock settings or custom..and if so what are they and what do they mean... i have a STB, SFC, LCA's and now eibachs on stock shocks
thanks
Old May 26, 2003 | 07:18 PM
DaddySS's Avatar
Default Re: Lowering car and Alignments
go with the stock specs.
Old May 26, 2003 | 11:34 PM
trackbird's Avatar
Depends on what you want to do....did you lower it for looks alone, or do you want better handling? For increased grip, I'd add some negative camber (-.7 to -1 degree of camber), 4.5 degrees caster and 0 toe (not in or out). THose settings will give you reasonable (even quite good) tire life, and the increase in handling performance will be noticeable. Just my thoughts....
