Which setting to use on lca relo brackets?
You can re-use your stock bolts. I use a lil' white lithium grease on the outsides of the bushings. Some folks use antisieze. Also...I use regular hi-temp wheel bearing grease to lube the bushings.
Also.....if your weld on LCA's aren't located/positioned corectly prior to weld, you may find that your wheels sit further forward in the wheel well than they should.
Suspension should be loaded during LCA mock up, and LCA position checked fo true prior to the weld, or you'll be doing (A)...buying adjustable LCA's, or (B).....cutting off your brand new relo's for a proper install.
There was a thread about weld on LCA's awhile back.....do a search for more info if inclined.
