Normal for solid rod ends?
Old Aug 29, 2007 | 02:07 PM
81LS1Camaro's Avatar
Default Normal for solid rod ends?
I have all spohn suspension with solid rod ends. Makes alot of noise hitting bumps and making tight turns (i have a spool). Just wondering if its normal.
Old Aug 29, 2007 | 04:29 PM
MeentSS02's Avatar
Kleeborp the Moderator™
That's been my experience with rod ends - they usually come with some road noise. You can't beat their performance though.
Old Aug 30, 2007 | 04:20 AM
revtime's Avatar
Yes its normal. I have all rod ends and a spool as well. Just check everything on a regular basis to make sure it all is staying tight.
Its a PITA but a regular checkup of all nuts and bolts will keep you safer out on the road as you can catch any small issues before they turn into larger ones.
