someone help !!!
Old Aug 31, 2007 | 10:51 PM
CULATR's Avatar
Default someone help !!!
ok when i bought my car it had a slp line lock on it i dont car for this style line lock so i just want to return it to stock. i have the stock line to replace the slp version, but what do i need to do to change this out im planning on flushing the brake fluid and putting new rotors and pads and im good on that but on changing out this line im clueless someone help what do i do also is there sealant that goes on the threads on each side of the stock line when putting it on to also do i have to bleed this too??? HELP ME Please!
Old Sep 1, 2007 | 10:20 AM
Switchblade's Avatar
The line lock kits come with a custom set of brake lines (only 2) that are req'd to install to the system. During the installation two OEM brake lines (connecting from the abs/brake modulator to the master cylinder) need to be replaced. These custom lines are rerouted to the line lock switch, and the holes on the abs modulator (where the two oem brakelines were installed) are sealed with a set of plugs.
To remove the system - you need to either fab up or get the oem brake lines 1st before you do anything else. Once you have the system removed and the oem brakelines installed, then you need to bleed the brakes.
Old Sep 1, 2007 | 11:02 PM
CULATR's Avatar
ok yea i already found me some oem lines so now all i do is replace them & bleed the brakes... hey thanks man i thought there might be something else besides that ..........thanks i appreciate it !
Old Sep 1, 2007 | 11:12 PM
SS SLP2's Avatar
PS ::Connect brake line to master cyl and the ABS block start it but leave it loose,remove cap from master cyl and let the lines grivity bleed watch the loose connection untill all air is out and run pure fluid ( may shake the line a little to help bleed ( REMEMBER BRAKE FLUID WILL REMOVE PAINT
I placed plastic sheet over fender)if does not gravity bleed blow into master cyl and have some one watch for fluid at ABS block >>>THIS way you do not have to bleed the brakes from under car- I had no problem of any kind,after useing this connection 7 years ago
just my .02' Johnny
Old Sep 1, 2007 | 11:17 PM
CULATR's Avatar
hey thanks i appreciate it alot!!
