grinding sound....
the PHR was just put in today, so i know it has nothing to do with that. everything else in my sig was there when the grinding sound started happening, but it did not happen when i had only the sway bars in and nothing else.
i got up under the car and looked all over the place, but can't find anything with any grinding damage on it, and everything is still torqued down really tight (i put blue "service removable" loctite on all the jam nuts, on the torque arm bolts going thru the rear end, and on the two bolts on the torque arm that hold the arm to the mounting bracket at the rear)....and looking at the "clean" part of the rod ends on the LCA's, they are not articulating anywhere near enough to be outside their range of articulation (in other words, the edges of the rod ends are not hitting the "sleeves" that are inserted into them). anyone have any idea what may be causing it?
the only thing i can think is maybe the emergency brake cable brackets, since i cut the one side of the brackets off to make the LCA relocation brackets fit....but i couldn't see any evidence of scraping or grinding there, either....also, it does not do it when i take the turn really slow (like anything under 5 MPH), but if i go a bit faster (5+ MPH), it does it.
why would it have changed just by putting on the LCA's/relocation brackets? the torque arm was installed before the LCA's, and everything was fine....it only started doing it after the LCA's & brackets were put on....and as far as i can tell, it only happens when making right-hand turns. i'll also give it a try with left-hand turns soon and see if it does the same thing.
sorry for the confusion.....first post has been edited.
anything else you can think of?
