Comp enginering rear shocks problem?
Old Oct 28, 2007 | 04:18 AM
BLOWN SS/T's Avatar
Default Comp enginering rear shocks problem?
So I bought some comp enginering rear shocks 3way from speed inc. I just got them and was going to mount them, I tried to set them to 50/50 but they only click once to the last setting, anybody know whats going on or what I need to do? I can spin them around but they only click at the last setting once.
I wanted to get these in today for the track, my stock shock are gone.
Old Oct 29, 2007 | 01:01 AM
BLOWN SS/T's Avatar
Any suggestions?
Old Oct 29, 2007 | 09:08 PM
98silvertacrbn's Avatar
Depress them all the way down. Then turn them clockwise two complete turns and stop on the setting that you want
Old Oct 29, 2007 | 11:03 PM
BLOWN SS/T's Avatar
They only stop at the last setting only clicking once at that setting?
Old Oct 30, 2007 | 09:54 AM
nicks2ndz's Avatar
follow directions above and just stop at the setting and stroke it by hand....you'll be able to feel what setting its on....50/50 is easy to stroke by hand 40/60 takes a good bit of force 30/70 i had to stick the shock bottom on the ground and use two hands to compress
Old Oct 30, 2007 | 04:12 PM
BLOWN SS/T's Avatar
But it doesn't click on the 50/50 setting, and when it does make the sound the arrow is indicating that it's on the last setting?
Old Oct 31, 2007 | 11:57 AM
nicks2ndz's Avatar
the set i have on my camaro doesn't click...the set i have on my oldsmobile does...not sure why...but when you rotate and stroke it you will know the diff and know if your on 50/50
