Front shock adjustment problem?
Old Nov 2, 2007 | 09:54 AM
Razorbackfan's Avatar
Default Front shock adjustment problem?
I just replaced my front shocks and reinstalled the stock springs. When you tighten the shock nut do you tighten it all the way? Does this compress the spring more and lower the car in the front?
I notice now with the stock springs the rear sits higher than the front and was wondering if this was the reason.
I replaced all upper/lower balljoints, both front bearing hubs, both outer tie rods ends, 4 stock springs, front shocks and 4 rotors and pads.
