Eibach and Bilstein Question
Old Nov 11, 2007 | 06:09 PM
my01ws6's Avatar
Default Eibach and Bilstein Question
Ok well I just got finished putting on a set of Bilsteins and Sportline springs...the ride quality has gotten 100% better and I am in no way disappointed in the direction I went.
BUT now Im wondering if switching to the prokit will make the ride just a little better or ALOT better?
Has anyone on here has experience with Bilsteins and both sportline and prokit springs?
Old Nov 11, 2007 | 08:10 PM
Mojave's Avatar
Sportlines are too low for the spring rates, and you end up hitting the bump stops. Prokits aren't the best choice, but are a much better match for height/rate than the Sportlines.
Old Nov 11, 2007 | 09:03 PM
my01ws6's Avatar
is it worth the hassle to switch them out? will it make it ride that much better?
Old Nov 11, 2007 | 09:40 PM
Out1aw's Avatar
There are a lot of things that many could write in here to convince you to switch over, and all truthful. So simply put: DO IT.
Old Nov 14, 2007 | 08:20 AM
sgarnett's Avatar
Personally, I'd choose the Strano springs instead of ProKits. IMHO, the ProKits are still too low for the soft rate or vice-versa, at least in the rear.
Old Nov 14, 2007 | 08:55 AM
BobDoLe's Avatar
even with the pro-kit, i was hitting the rear bumpstops. i had to remove the bumpstop spacer to resolve that.
