Which LCA's??????
Based on your driving I would recommend just the basic non-adjustable set-up up with a set of relocation brackets. The control arms will help to eliminate the flex found in the stock control arms and reduce bushing deflection for improved traction. The relocation brackets are available bolt in or weld in and lower the rear of the control arm and work as a anti-squat bracket. When you lowered your car you altered the control arm angle and this is the main reason you may be seeing some traction loss. The relocation brackets bolt to the rear end and lower the control arm back to as if the vehcile was never lowered. This way you can lower the vehicle but still maintain the correct suspension geometry and instant center point.
Please take a look at the links below and if you have any questions please ask. This set-up would only cost you $199 for both items.
Control Arms- www.umiperformance.com/2015
Relocation Brackets- www.umiperformance.com/2012
Thank you!
Ryan
