bmr lca relocation brackets
Old Jun 22, 2003 | 06:24 PM
sal346's Avatar
Default bmr lca relocation brackets
i bought a set awhile ago and im gonna install them tomorrow, my car is lowered with a prokit and i noticed that there are two bolt holes on the brackets to reinstall the lca's into, do lowered cars install on the lower bolt hole or does it not matter?
TIA,
sal
Old Jun 22, 2003 | 07:45 PM
DaddySS's Avatar
Default Re: bmr lca relocation brackets
Depends, use the hole that gives you a good angle on the bar, in most cases it will be the lower hole.
Old Jun 22, 2003 | 08:58 PM
Fulton 1's Avatar
You want the LCAs to be parallel to the ground or slightly lower at the rear (axle side). This meant using the lowest hole for me with BMR bolt-in relocation brackets and Prokit springs. I'm guessing it'll be the lower hole for you too.
Old Jun 23, 2003 | 01:34 AM
2001CamaroGuy's Avatar
for most people its the lowest...was for me also....
Old Jun 23, 2003 | 11:19 AM
sal346's Avatar
thanks for the info, i wont have a chance to install them today but thats the only question i had about these, later,
sal
Old Jun 27, 2003 | 11:28 PM
jruss's Avatar
was the top hole for me on my hotchkins springs...lcas should be parallel to grounf btw
