Problem?
Old Dec 20, 2007 | 08:33 PM
Z28FirefighterI1's Avatar
Default Problem?
We'll I had a little mishap at the track (sideways @110 more info here https://ls1tech.com/forums/racer-s-lounge/827637-what-night.html ) and now I have right side wheel hop thats pretty bad. I had flat spot in all of my tire so I put a different set on and the car dosen't shake or anything, the car feels good exept the wheel hop. My car never had a problem with wheel hop, I have BMR - TA, adj pan arm and LCA's, a spohn sway bar. The rear end looks centered nothing looks bent. Any idea's?
Old Dec 21, 2007 | 02:43 PM
Come on guys any idea's?
Old Dec 21, 2007 | 05:20 PM
trackbird's Avatar
I'd look for a bent axle and I'd check the rear shocks for damage or being bent (not real likely, but I'd look) and I'd check the LCA's and PHB bushings and see if you have one that's cracked, split or broken.
That's where I'd start.
Old Dec 21, 2007 | 05:42 PM
I should be getting under the car tomorrow and try to dig a little deeper. Thanks for the input, I'll let you know if I find anything.
